Forums >> Revit Structure >> Tips & Tricks >> Adjusting the analytical line in a revit family
Tue, Aug 25, 2009 at 1:45:54 PM | Adjusting the analytical line in a revit family
jetfavre
I have an issue where i need the analytical line on a roof joist to be at the joist seat (where it attached to the wall) so when i export to risa the analytical lines connect. what is the easiest way to adjust the analytical line?
Fri, Mar 5, 2010 at 9:16:30 AM | Adjusting the analytical line in a revit family
pensing2
Offset the joist so that it is I'm guessing 2.5" up and sitting on the beam, and then open element properties and change your vertical projection so that it is at your T/ steel elevation at that location rather than probably at T/joist.
Making something an analytical line....
Thu, Jan 22, 2009 at 9:09:32 AM
Installing analytical line into a in-place framing family?
Thu, Oct 15, 2009 at 2:37:44 AM
Problem with adding analytical lines into Generic Model line template
Wed, Apr 10, 2013 at 3:31:06 PM
Analytical Line
Tue, May 23, 2006 at 6:00:18 AM
Analyical lines Structural Framing
Mon, May 4, 2009 at 3:21:04 AM
Page generation time: 1.9334
