Forums >> Revit Building >> Technical Support >> Split face aournd a corner...
Tue, Aug 25, 2009 at 12:58:27 PM | Split face aournd a corner...
atkinsonhall
I'm trying to use split face tool to show a soldier course around an outside corner of the building. Its easy enough to split both walls, but it the split line doesnt reach the corner, leaving a gap Cryingdue the wall join?).
any ideas?
Tue, Aug 25, 2009 at 1:15:41 PM | Split face aournd a corner...
tim123
4 Stars: 19 Votes
The end of the wall is also a face, so you need to split that also.
I would rather use the hosted sweep to do a soldier course.  You will have more control, can shift it in or out and it will cut the wall and show in sections.  Just load the soldier course profile into the sweep.  You can also set one in the sweeps in the wall properties, then it will automatically be in all the walls that need a soldier course.
Tue, Aug 25, 2009 at 2:14:22 PM | Split face aournd a corner...
atkinsonhall
thanks for the help.
i would like to use sweeps for the reasons you mentioned. but they have caused other problems in the past. like when i want to pull the brick veneer down to a lower level brick ledge....if i also move the sweep, it will no loger be cut by doors....as well as a few other wierd problems.
i may have to look at it again.
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:11 PM
SPLIT FACE BLOCK
Tue, Jul 18, 2006 at 10:41:24 AM
Split face on floor?
Wed, Nov 18, 2015 at 1:16:28 PM
Edit Split Face on Ceiling
Mon, Jan 25, 2010 at 4:42:26 PM
Using Split Face
Fri, Jul 12, 2013 at 11:00:40 AM
Page generation time: 1.8182
