11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Is there a way to limit all the 'backup' files that Revit makes?
Tue, Aug 25, 2009 at 8:33:19 AM | Is there a way to limit all the 'backup' files that Revit makes?
arusso5
I am modifying and creating a number of new families for my firm and I am making so many files with each family I edit or create.  Is there any way to limit this?  I know when I save I can change the number of maximum backups, but that doesn't seem to stop what I'm talking about.  I have three backups of every file I've created or modified.  How many backups should you keep?  Where do you keep them?  This just seems like a lot of additional file space that is required.
 Is there a way to remove them automatically through Revit?  What about all the journal files and the project backup folder.  How often should these be emptied?
Any suggestions would be welcomed.
Thanks.
Tue, Aug 25, 2009 at 8:47:25 AM | Is there a way to limit all the 'backup' files that Revit makes?
From your HELP
 Specifying the Number of Backup Files function hideInfo() { info = document.getElementById('infoline'); info.innerHTML = ' '; info.style.visibility = 'hidden'; } function showInfo(title) { info = document.getElementById('infoline'); info.innerHTML = title; info.style.visibility='visible'; }
By default, Revit Architecture saves up to 3 backup files for each project. You can change the number of backup files that Revit Architecture saves for a project.
To specify the number of backup files
  1. Click File menu Save As.
  2. In the Save As dialog, click Options.
  3. In the File Save Options dialog, for Maximum backups, specify the number of backup files to save.
  4. Click OK.
  5. Click Save
For the number ofjournal files - Settings / Options.
Recovering a file from Backup Files W/O/ the original File
Fri, Feb 6, 2015 at 9:40:43 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
can you save backup files to a different folder? [ 1 2 3 ]
Wed, Sep 16, 2015 at 4:57:04 PM
39
backup files
Tue, Feb 13, 2007 at 6:50:35 AM
Backup files
Tue, Dec 23, 2008 at 1:48:35 PM
14
Page generation time: 2.0260
