Forums >> Revit Building >> Technical Support >> Help! Revit Crashing when I...
Tue, Aug 25, 2009 at 8:06:06 AM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
When I am in a project (even a newly created one) Revit will crash when I select 'Load Family'.
Every time.
I have reinstalled Revit 2010 with the Service Pack 1 as well as the recent patch that Autodesk has released and I am still having this problem.
Anyone know what to do?
Tue, Aug 25, 2009 at 8:53:50 AM | Help! Revit Crashing when I...
Do you conform to these guidelines?
http://images.autodesk.com/adsk/file..._tech_note.pdf
Tue, Aug 25, 2009 at 9:07:36 AM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
I could forward this on to my IT person, but we have been running Revit 2010 since it came out.  It was only just last Friday that this started happening.
I didn't know if this has been known to have happened before?
I am guessing my machine meets the criteria outlined, and all of the machines are the same; but this hasn't happened on any of the other two workstations we have here.
So then that leads me to ask, is it the program or the machine?  I'm guessing since this is about the only time that Revit crashes (with each attempt to do that particular command), that it is some glitch within Revit.  I just didn't know if there is a known way to fix this problem.
Thanks for responding btw
Tue, Aug 25, 2009 at 10:11:02 AM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
Our workstations meet and exceed the necessary criteria that Revit recommends using.  It is only on my system that the 'Load Family' will make it crash.
Tried replacing the INI file with another workstation's thinking that might resolve any bugs in the INI file, but that didn't do any better.
We are using 3gigs with the 3gig switch enabled.  I know others have mentioned upgrading to use more than 3, but again, my workstation is the only one that seems to be having this issue.
Tue, Aug 25, 2009 at 10:18:56 AM | Help! Revit Crashing when I...
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Mars
It is probably your virtual memory, open the worksharing monitor and open the system performance. There is a graph on there you can monitor to see whats is causing the crash. My guess is your virtual memory redlines.
Is your hardware acceleration on? if so turn it off and have your IT guy set your "pagefile" as high as it will go.
Tue, Aug 25, 2009 at 11:05:55 AM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
Tue, Aug 25, 2009 at 11:11:03 AM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
Yeah, I do not work with the Hardware Accelerater turned on.  Found that to be a big pain in the but.  We do not have the workshare monitor installed.  However, we did already max the "filepage" size.
Any other suggestions or thoughts?
Tue, Aug 25, 2009 at 11:11:31 AM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
And thanks btw for helping me with this.
Tue, Aug 25, 2009 at 11:39:48 AM | Help! Revit Crashing when I...
mars ... have you maintained your local drive?  Run cc-cleaner.
Tue, Aug 25, 2009 at 1:05:10 PM | Help! Revit Crashing when I...
MARS1276
1 Stars: 1 Votes
No, my drafting supervisor is also the IT man.  I showed it to him and upon further review he is very skeptical about installing a program that will mess with the computer's registry file in any way.
revit crashing
Mon, Jan 23, 2006 at 2:28:30 PM
Crashing During Render and Changing Views
Wed, Mar 12, 2014 at 2:54:56 PM
Ceiling Tags Crashing Program
Sat, Dec 15, 2007 at 3:03:16 PM
Revit 2012 Crashing
Thu, Oct 13, 2011 at 12:42:22 PM
Revit 2013 crashing on printing
Tue, Feb 26, 2013 at 1:13:49 AM
Page generation time: 1.5291
