Forums >> Revit Building >> Technical Support >> a few issues i need help with (drainpipes, joining walls)
Mon, Aug 24, 2009 at 1:32:17 PM | a few issues i need help with (drainpipes, joining walls)
daveyboy86
i need a bit of help
 i want to add drainpipes to my model in 3d but not sure of the best approach.
 i also have two walls on top of each other modelled as in place extrusions.  they both need different materials and are both different widths (like a stacked wall), however, i need to place windows that pass through both walls but i can't do this without joining the two extrusions. i am comfortable with this but when i do join them, whichever one i click second inherits the material of the first.
i have assigned different material to each extrusion.  i was going to use split face and paint to get the material definition but i can't seem to use the split face tool on these in-place extruded walls
 any suggestions will be much appreciated
Mon, Aug 24, 2009 at 1:45:19 PM | a few issues i need help with (drainpipes, joining walls)
If you had used walls, you would not have this problem because the window would cut both walls.  You may have to use a void to cut these extrusions.
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Wall Joining Issue Revit 2015
Wed, Nov 4, 2015 at 7:56:51 AM
11
once again, stacked walls......ahhhh!!
Wed, Jul 9, 2008 at 8:52:58 AM
Joining Walls at Awkward Angles
Tue, Mar 11, 2014 at 8:31:13 AM
Keeping walls from snapping
Fri, Jul 21, 2006 at 12:06:03 PM
Page generation time: 1.1602
