Forums >> Revit Building >> Technical Support >> When editing materials through properties, only two show up??
Mon, Aug 24, 2009 at 11:31:23 AM | When editing materials through properties, only two show up??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
 In Revit 2009 when say I was editing the materials in a ceiling and I click the '...' button to access the materials menu, it would show all materials and hightlight the current material that was currently in the ceiling.
 Now in 2010, when I go to the materials menu thorugh the same method through the ceiling properties, it only comes up with 2 materials and neither one is the current material for that property?  I have to go to the drop down select <ALL> and view all the materials, and search for the material I was using.
 My coworker does not have this problem with his 2010 Revit.  I'm stumped as how to fix this?
Thanks,
Lorne
Denver, CO
Revit Architecture
Mon, Aug 24, 2009 at 11:51:54 AM | When editing materials through properties, only two show up??
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Different template file with different materials loaded?
Mon, Aug 24, 2009 at 11:59:53 AM | When editing materials through properties, only two show up??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I wish it were that simple.  We have the same template we use throughout the office.
We have all the same materials in our projects.  It's just when I go into materials through properties, it starts with only two materials and doesn't list them all.
Denver, CO
Revit Architecture
Mon, Aug 24, 2009 at 12:46:35 PM | When editing materials through properties, only two show up??
tim123
4 Stars: 19 Votes
In Options, uunder rendering, are you pointing to the same place for Render Appearance Library Location?
Mon, Aug 24, 2009 at 2:15:06 PM | When editing materials through properties, only two show up??
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Forget about the properties dialog box. Take a step back. If you go straight to Manage > Materials (R2010) do you see all the materials listed / loaded there?
Mon, Aug 24, 2009 at 2:16:54 PM | When editing materials through properties, only two show up??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
assetlibrary_base.fbx
Yea it's pointing to the file above (default by Revit).  I also have another renderappearance path that is our custom one...but when I open materials by not going through an objects properties, it shows all materials.  When I go through the objects properties, only two show, until I select <ALL> in the drop down menu in materials.
Make sense?
Denver, CO
Revit Architecture
Tue, Nov 24, 2009 at 10:03:54 AM | When editing materials through properties, only two show up??
jonathanholley
We've just experienced this ourselves, and it was very frustrating until we sorted out the bug. The problem is that the Material Class selector seems to default to the (alphabetically) first Filter in the list. Usually, this is <All>, which since it shows all Materials is a guarantee that the material you want to select will in fact be in the list and selectable. I'm going to wager that someone on your project created a new material frin scratch and didn't assign it a Material Class under the filter criteria, which Revit interprets as a blank, which it sorts *before* <All>. If you really want an unassigned material, you have to manually type "Unassigned" -- the blank space will throw things out of wack! To fix, go through the fo through the two materials and assign them a Material Class in the Identity tab. Once you've changed them, behavior should return to normal.
Tue, Nov 24, 2009 at 11:02:33 AM | When editing materials through properties, only two show up??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Johnathan YES!!!
That worked...It's always so simple that I overlook and don't even think about.
Now we show all.  It was a simple bug that wasn't terrible to deal with...but now we don't have to deal with it thanks to you.
Much obliged,
Lorne
Denver, CO
Revit Architecture
Tue, Mar 13, 2012 at 3:28:52 PM | When editing materials through properties, only two show up??
cyurechuk
Lorne17- You rocked my world.  Thank you so much!  <3
Tue, Mar 13, 2012 at 3:38:21 PM | When editing materials through properties, only two show up??
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Don't thank me, thank Johnathan. Smile
Denver, CO
Revit Architecture
Wed, Mar 14, 2012 at 12:30:06 AM | Material Class Default Problem
cyurechuk
Oh yes, my bad- Thank you so much Jonathanholley.  I am so happy there is internet these days.  I cannot imagine the time it saves to be able to search for problems so quickly and find solutions- A-Mazing!
Editing materials in revit MEP 2008
Fri, Aug 17, 2007 at 3:31:21 AM
Materials Management HELP!!
Tue, Jul 26, 2011 at 10:50:31 AM
Rendering materials within components
Mon, Apr 24, 2006 at 1:49:32 PM
Missing Materials
Wed, Jun 19, 2013 at 2:22:26 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
Page generation time: 3.3546
