Forums >> Revit Building >> Technical Support >> Can't insert doors/components in level
Sun, Aug 23, 2009 at 4:46:03 PM | Can't insert doors/components in level
jnbt28
I'm working on a multi-level house, and when I try to insert a door I am told that "Can't cut instance of 30" x 84" out of Wall." Also, when I go to insert a component, it shows up on the First Floor Level, and I have to copy to clipboard and paste to the basement level. What am I doing wrong?
Whenever I go to the basement level's properties and click on "View Range" it tells me that the Associated Level is the First Floor. Is this the issue? How do I change that?
Mon, Aug 24, 2009 at 7:01:05 AM | Can't insert doors/components in level
Your problem is with your views.  They were not created in association with the level.  In REVIT, you don't just copy a fllor plan, give it a new name and change it's view range. Learn to use your HELP because it is very good in REVIT.  Here is what it says:
Creating a Plan View
  1. Click View menu New Floor Plan, or on the View tab of the Design Bar, click Floor Plan.
  2. From the New Plan dialog, select one or more levels for which you want to create a plan view.
  3. If you wish to create a plan view for a level that has an existing plan view, clear Do not duplicate existing views.
  4. For Scale, select an appropriate view scale for the new view.
  5. Click OK.
Mon, Aug 24, 2009 at 7:42:31 AM | Can't insert doors/components in level
jnbt28
Thank you! This is the solution that I finally found when googling the issue last night. I suppose I just didn't know the "correct" question to ask my help.
Thu, Apr 14, 2011 at 11:20:19 PM | Can't insert doors/components in level
Zeal
Very helpful tip. I just came accross this problem and I was chasing my tail to try and fix it. Made a new floor plan from the pull down menu and the problem resolved itself... such an odd problem
everything inserting on the wrong level?
Mon, Jul 9, 2012 at 11:09:27 AM
Components on Level are Grey
Wed, Apr 17, 2013 at 12:56:06 PM
Furniture, Doors, Casework, In Place Components have x-ray, see through properti
Wed, Jan 25, 2012 at 4:07:10 PM
Can't insert door to wall
Thu, Oct 8, 2020 at 6:46:39 AM
Doors flip on insert
Mon, Feb 10, 2014 at 1:50:08 AM
Page generation time: 3.0748
