Forums >> Revit Building >> Technical Support >> Hotfix - Crash when deleting or modifying walls
Sat, Aug 22, 2009 at 8:19:46 AM | Hotfix - Crash when deleting or modifying walls
4 Stars: 205 Votes
To all of you, directly from Autodesk:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13778933&linkID=9273944&CMP=OTC-RSSSUP01
Published date: 2009-Aug-21 ID: DL13778933
Applies to:
Autodesk®Revit Architecture 2010
Autodesk®Revit MEP 2010
Autodesk® Revit Structure 2010
This hotfix addresses issues related to deleting or modifying walls, a crash may occur.
Make sure to download the correct patch for your operating system (32 or 64 bit).
The Readme contains the latest information regarding the installation and use of this update. It is strongly recommended that you read the entire document before you apply the update to your product. For your reference, you should save the Readme to your hard drive or print a copy.
Edited on: Sat, Aug 22, 2009 at 8:22:27 AM
Crash!!!!
Thu, May 5, 2011 at 4:09:10 PM
Deleting Levels without deleting associated walls
Thu, Jul 30, 2015 at 2:43:47 PM
Revit Fatal Error
Sat, Jan 9, 2010 at 7:30:35 PM
crash recovery
Thu, Apr 23, 2009 at 7:02:48 PM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 7:38:36 AM
11
Page generation time: 2.1952
