Forums >> Revit Building >> Technical Support >> Crop Region Invisible
Fri, Aug 21, 2009 at 12:02:41 PM | Crop Region Invisible
hunterfloyd
This is a huge annoyance and has never happened to me before today.  For some reason when I create a new interior or exterior elevation, the new view shows up with no heighth to it.  so, it shows nothing except a line of the floor.  i've seen this happen similarly numerous times, but this time, I cannot grab or see the crop region (which is ticked on in my view properties).... also, is there a way to format your elevations to show a particular height automatically when you place them?
HuntFlo
Fri, Aug 21, 2009 at 12:43:51 PM | Crop Region Invisible
Known problem ... this was posted on AUGI by the author listed .  but I have not tried it.
Create a scope box and name it. While on the scope box properties, make sure the options "View Visible" has the elevation you want to see as overridden to be "Visible". Now go to the elevation view (you won't see anything because your crop region is set to 0) and select the option to "Not crop the view". At this point you will see the scope box. Select your problematic crop region, go to properties and link it to the scope box you just created. The crop region will extend to the scope box extents. Now you can delete the scope box and your crop region will remain where the edges of the scope box were. But at least now you can drag it to where you want and turn on "Crop view" again. Andre Carvalho
Fri, Aug 21, 2009 at 12:55:51 PM | Crop Region Invisible
hunterfloyd
figured it out.  when you place a an elevation while editing a design option, the crop region does not show up later for some reason.
HuntFlo
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:07 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:29 PM
crop region - elevations
Fri, Oct 23, 2009 at 12:43:33 PM
Room Tags Outside Crop Region
Sun, Sep 10, 2006 at 8:05:26 PM
datum controls and crop region
Fri, Oct 13, 2006 at 4:43:25 PM
Page generation time: 0.2608
