Forums >> Revit Building >> Technical Support >> Surface pattern vs. Render Pattern
Fri, Aug 21, 2009 at 11:15:38 AM | Surface pattern vs. Render Pattern
TravisStuntebeck
I have an existing building with utility brick on it that I am attempting to re-create.  I have found the correct surface pattern, imported it, and all the joints line up and all of that.  My next problem is attempting to find a rendering pattern that matches this surface pattern.  Has anyone else encountered this? If so what did you do? Any help would be greatly appreciated!
Fri, Aug 21, 2009 at 3:12:33 PM | Surface pattern vs. Render Pattern
tim123
4 Stars: 19 Votes
What kind of pattern is it.  If it's not standard you will need to find a map of the brickwork or create one from a photograph.
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Surface pattern and Render Appearance Do Not Match
Tue, May 7, 2013 at 11:44:06 AM
Page generation time: 0.3351
