19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Area Schedule Estimated Cost
4 Posts No Rating |
I´ve tried to make an area schedule where i can calculate estimated total cost. I´ve made an area plan and then in the area schedule i´ve added the parameter Cost by myself and also added Area and Area Type. When i make an Calculated value that i call "Estimated Total Cost" with the string "Area * Cost / 1" i only get the asnwer "Improper use of boolean expressions". What am i doing wrong ?
19 Posts No Rating |
I played around with trying to recreate this error and the only problem I could think of is that your Cost field may not have the correct units (currency). Check that to make sure it's not "text" or some other incalculable unit.
Material takeoff , Cost using both area and volume |
Wed, Nov 20, 2013 at 7:25:01 AM
Material cost per sq ft formula |
Mon, Sep 21, 2009 at 9:06:24 AM
calculated value - cost |
Wed, Aug 13, 2014 at 11:18:35 AM
Cost Estimation |
Mon, Aug 11, 2008 at 12:40:24 PM
Material Cost Analysis in Schedules |
Wed, Jan 13, 2010 at 6:55:37 PM
