Forums >> Revit Building >> Technical Support >> anotate dimension in mass
Thu, Aug 20, 2009 at 7:24:49 PM | anotate dimension in mass
balbimex
Hy,
I´ve been trying do make a skateboard ramp...I could model a bowl using in-place model. The problem is that I cannot add a dimension for the radius when I make a section. Does anyone know how to solve this problem?
Thank you!
Fri, Aug 21, 2009 at 6:29:33 AM | anotate dimension in mass
Some items do not cut in REVIT.  You can find out what is cuttable in your help.  You may have to add linework to dimension this.
dimension tool for mass- non orthogonal faces
Fri, Jul 31, 2020 at 4:40:36 PM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:54 AM
Activate Dimension
Tue, Dec 13, 2011 at 12:53:44 PM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Help wth Mass Please !
Wed, Nov 25, 2009 at 2:53:24 PM
Page generation time: 0.1445
