15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Wall Opening
13 Posts No Rating |
I am having a problem getting the desired result in section from a window with a built in sill. I have created a family of window with the sill as an extrusion that adjusts to the window size. However, when I go to section the sill is not cutting the wall. How do I make an extrusion cut the wall? I also tried using an opening to cut the wall but the problem with that is, that the opening cuts the entire depth of the wall even when multiple material are used. What I really need is the sill/head to just cut to its extrusion depth leaving the other layers uncut. How?
You will need to change the wall cut in your famil. The template comes with an opening cut...plain and simple but you need an opening plus a void for your sill (header?). Revit will not allow both in the family so delete the opening cut and do it all with a void or voids assigned to cut the wall.
I will give that a try...thanks for the reply.
Control the depth of a wall opening? |
Wed, Jan 19, 2011 at 2:09:23 PM
Wall Openings |
Mon, Mar 9, 2009 at 2:40:22 PM
Why does the wall opening cut only go up 2/3 the height of the wall? |
Sun, Feb 18, 2007 at 8:53:25 AM
Wall Opening |
Tue, Jul 10, 2007 at 10:24:02 PM
Windows/opening/curtain system on inclined wall |
Tue, Apr 21, 2009 at 5:16:45 AM
