Forums >> Revit Systems >> Technical Support >> .ies files from Revit export to 3Ds Max rotate incorrectly
Wed, Aug 19, 2009 at 2:06:14 PM | .ies files from Revit export to 3Ds Max rotate incorrectly
iREV
3.5 Stars: 3 Votes
I am working with Revit MEP 2010 exporting a .fbx file for import to 3ds Max Design 2010.  I have rotated and oriented the .ies files in Revit to the desired orientation.  Upon import into 3ds max design the .ies files orientation changes along with the emit shape and seems to be unpredictable.  Does anyone know why this is? Also, is there a global way to change the lumens for fixtures that are the same in 3ds max?
Revit to 3DS Max and creating FBX files
Fri, Apr 26, 2024 at 4:30:41 AM
REVIT and 3ds MAX
Mon, Apr 4, 2005 at 4:45:15 PM
is there a way to import a revit family into 3ds max?
Fri, Oct 8, 2010 at 4:28:15 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:53 AM
IES files in Revit
Mon, Feb 6, 2017 at 4:00:14 PM
Page generation time: 2.9127
