26 Users Online (24 Members):
Forums >> Revit Building >> Tips & Tricks >> When selecting an object the element ribbon panel is not visible in Revit 2010
I don't know if you guys, already see this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13540984&linkID=9243099&CMP=OTC-RSSSUP01 Published date: 2009-Aug-17 ID: TS13540984 Applies to:Autodesk® Revit® Architecture 2010Autodesk® Revit® MEP 2010Autodesk® Revit® Structure 2010 Issue When you add or select an object in Revit 2010, the Element Ribbon Panel does not appear. Solution This typically occurs when the workstation is running graphics card management software, which modifies or controls the window display. Verify if you are running window management software, typically from a video driver or graphics card control panel. Examples would include nView from Nvidia or HydraVision from ATI. The Windows Control Panel will show these applications installed. If the software is present: - Close Revit 2010.
- Disable the software or any additional window management software. Make sure that no software is attempting to control the position or graphics of windows.
- Launch Revit 2010, and highlight an object to verify the element ribbon panel displays as expected below:
Edited on: Wed, Aug 19, 2009 at 12:35:32 PM
10 Posts No Rating |
It never happens with me
décio ferreira, arq. |
Lucky guy....
I get this all the freakin time... but I just hold the cursor over the ribbon and/or deselect the object related to the error, and it comes back.
qab
^_^
Debian + VirtualBox + Revit
Missing Element Properties Ribbon |
Fri, Aug 20, 2010 at 2:43:20 PM
Revit 2010 UI Problem |
Wed, Jan 13, 2010 at 1:45:49 PM
Ribbon Issues |
Tue, Jan 14, 2014 at 9:51:50 AM
Problem selecting glass using tab key |
Thu, Mar 21, 2019 at 1:17:37 PM
Selecting Objects Help!!!!!!! |
Wed, Jun 10, 2009 at 8:23:52 AM
