9 Users Online (7 Members):
Forums >> Revit Structure >> Technical Support >> Footings w/ eccentricity assigned
20 Posts No Rating |
I'm having trouble cleaning up the corners of my footings which have eccentricity assigned when they are attached to walls that are joined. I've been disallowing the wall join and draging the wall ends in order to clean-up the footing join then having to do linework in order to have the walls show properly in plan. Is there something i'm missing or is this an issue with footings assigned eccentricity?
2 Posts No Rating |
I also have footings w/ eccentricity and would like an easier way to clean up the corners. I've tried using the 'edit wall join' tool, to no avail. Does anyone out there have a better solution to this problem? Thanks, B
I ended up changing my footings structural usage in the 'edit type' to be 'retaining' rather than 'bearing'. It allowed me to clean up the corners without having to disallow join of my walls and do a bunch of line work.
Wall Footing Cleanup - A Problem |
Fri, Jun 25, 2010 at 3:01:52 PM
Footings for Slab Foundation |
Tue, Oct 30, 2007 at 7:05:08 AM
Auto Footings |
Tue, Apr 4, 2006 at 10:10:15 PM
Footings, getting double hidden lines and intersections suck! |
Fri, Aug 31, 2012 at 10:13:08 AM
isolated footings not showing up |
Wed, Jul 18, 2012 at 1:17:11 PM
