Forums >> General Discussion >> Wishlist >> Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM | Does anyone else wish that there was a toggle to make wall joins the default off
JsBach
 I can see many applications, especially in interiors and buildings without a lot of material changes, where you would want wall joins to be on. But I have found that the default wall joins setting to be frustrating. It is very time consuming to use the disallow join tool on every wall and the results are often unpredictable. I would like to see a global toggle to allow or disallow wall joins. It seems from talking to people and from reading the forums that this is a common point of frustration in learning Revit.
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Revit 2014 - Disallow wall joins by default
Tue, Jun 17, 2014 at 10:23:21 AM
Changing Default Wall Joins Revit 2011
Fri, Aug 13, 2010 at 4:14:12 PM
Disallowing All Curtain Wall Joins
Fri, Apr 29, 2016 at 8:48:30 AM
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
Page generation time: 0.8714
