Forums >> Revit Building >> Tips & Tricks >> Help! Edit Family
Wed, Aug 10, 2005 at 1:42:36 AM | Help! Edit Family
kinita
Hi, i am new to revit and we are currently introduce it to our uni for the first time Can someone please tell me how i can edit this block or family. This block was originally download from http://revit.autodesk.com/. The problem with it is-> i cant change or edit its colour or materials... Please, some revit- interllectual tell me why i cant edit a block?l Thanks
Wed, Nov 30, 2005 at 2:27:32 AM | RE: Help! Edit Family
BLIESNER
quite simple the model you are looking at was created and imported from 3ds max and therefore cannot be edited within revit.
Wed, Nov 30, 2005 at 11:41:21 PM | RE: Help! Edit Family
mwenta
5 Stars: 2 Votes
I see you posted this awhile ago but just in case you never got the answer that you were looking for here it is. You can change the properties of this model even though it is a DWG file. To do this you need to type in 'VV' (keyboard shortcut for 'Visibility/Graphic Overrides) once you do this you will get the 'Visibility/Graphics Overrides' dialog box. Select the 'Imported Categories' tab, after doing this select 'Object Styles...'. You will now have a new dialog box open and to the far right you will see materials, click to the right of the material and you will see a drop down box of materials for that family has in it. Simply pick and choose, now that only takes care of that family right now. The goal is to make that family editable from the within the project, as it stands right now you can only edit the materials from within the family. You will need to create 'Parameters' to allow you to do this. To do this you will need to select 'Family Types...' from the left. Once you have done that you will see a dialog box titled 'Family Types'. The only parameters that you will see are the Revit default ones. This is where you will need to 'Add' some. Select 'Add' and the 'Parameter Properties' dialog box will open. Here is where you will create your parameters. 'Family Parameter' will be selected by default, just leave it. Under 'Name' type in something (I chose 'Wood Cabinet' for the wood and 'Glass' for the glass, pretty creative huh?). Leave 'Discipline' alone and under 'Type' select 'material', under 'Group parameter under:' for materials I choose that category. This is just a way to organize your parameters there is no right or wrong way to do this. Finally I usually select 'Instance' rather than 'Type'. 'Instance' means that when you edit a family that it will change only that family. 'Type' means that when you edit a family that it will change every family within your project. With practice you will learn when to use each of them. Hope this helps, but I'm sure by now you have already figured this out. I attached the file that you posted for you to reverse engineer.
metric units in edit family
Wed, Jan 18, 2006 at 7:56:02 AM
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
not able to edit profile in sweep
Thu, Jun 29, 2017 at 2:49:46 PM
Edit .rfa as an in-place family? 2012 Architecture
Fri, Jul 27, 2012 at 1:01:38 PM
title block import/edit family issues
Sat, Apr 7, 2012 at 2:25:03 PM
Page generation time: 2.6702
