Forums >> Revit Systems >> Tips & Tricks >> Control your copy speed
Wed, Aug 19, 2009 at 2:04:28 AM | Control your copy speed
online2000
online2000 Avatar
Just in case some of you were not qaware of this..
is easier to copy items when you dont use icons: when you select an itme and then use the Ctlr key- u can copy+drag the item. This helps as I have to use the keyboardin another language sometimes- and this avoids the keyboard commands from interfering (something Autodesk may want to work on!!)
REVIt should find more ways of creating custom keys... uness its out thee.. and the process is limited to the shortcuts already given?
64703_CAOP6S13CAOJHGCICALNY5U4CAJZ2W2TCA9A1PL8CA6ZK55PCAGWRN5LCAGOCTR0CA2Y4BCICAEHYTVMCAM0YDXPCA0UIKF0CAY9DXFACAG4PEC9CAEVTPWECA95L1UYCAHO31B8CAOKBTHOCAZ2QODHCATTJ0UV.jpg
eli
Fri, Aug 28, 2009 at 9:15:51 AM | Control your copy speed
jhayden
jhayden Avatar
You can create custom keyboard commands, if that's what the last part of your post meant.
Controlling Revit animation speed
Tue, Sep 16, 2008 at 4:18:01 PM
How do I undo the double click to edit a family in 2013
Tue, Sep 17, 2013 at 1:05:11 PM
printing speed
Thu, Jan 24, 2008 at 9:31:57 AM
Walk Through Editing
Thu, May 3, 2012 at 1:03:20 PM
Mouse Speed
Tue, Jul 19, 2011 at 4:48:43 PM
Page generation time: 1.1578
