11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> ADDING WALL HEIGHT PARAMETER TO WALL SCHEDULES
3 Posts No Rating |
Is there an easy way to add wall height parameter to wall schedules? Thanks in advance. Andrew.
Since length and area are available in the schedule, I think you can figure out a way to find the height....
3 Posts No Rating |
...i think I know what you're getting at....area / length = height Thanks.
Keep in Mind that the Area Calculated is that of the Wall minus the openings, so your height calculation will not be accurate.
Welcome to the REvitlution!!! |
The property we really want scheduling access to is the wall 'unconnected height' and there doesn't seem to be any way to get your hands on it. A horrible work around is to create a 'project parameter' for the 'wall category' and then 'manually' enter the automatic 'unconnected height' into that project parameter field for each wall. That field is then schedulable. I'd wait until the DD is done before entering into this exercise and it's ugly as sin but technically it would work 100% as long as you complete due diligence. Don't shoot the messenger : )
2015 wall height |
Fri, Jul 10, 2015 at 9:17:02 AM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule? |
Thu, Apr 27, 2017 at 2:04:39 AM
Adding Weights to Schedules |
Mon, Apr 6, 2015 at 7:29:42 AM
How to include the Level parameter in Wall Schedule & quantities |
Mon, Sep 25, 2006 at 7:34:35 AM
Wall Openings - Changing Height |
Wed, Jan 28, 2009 at 8:05:26 AM
