Forums >> Revit Building >> Technical Support >> Interior Elevation linewieghts
Tue, Aug 18, 2009 at 5:21:44 PM | Interior Elevation linewieghts
cholden
cholden Avatar
RAC 2009
My interior elevation shows everything as same lineweight - the walls (which are cut), the cabinets (which are families), and the countertop (also a family) - all are a thick lineweight. My interior elevations are set up with a view template in which all the settings are correct. My object settings are also correct. The only overrides I have in the view template are on the cut walls. It seems like everything is overriding to match the lineweight of the cut walls. I can't figure out what is going on. I have saved up and restarted my computer. I have deleted and redone the elevations. Does anyone know what is going on? Please help! I am past the point of starting this project over and I really don't want to have to use the linework tool on every single element in every single interior elevation.
 Thx!
Wed, Aug 19, 2009 at 7:18:05 AM | Interior Elevation linewieghts
I don't believe this is a Revit issue - still think you have something set wrong.  Try going the other way.  Over-ride linework in VG on a couple of items and make them really large.  If that works then your setting are off somewhere.
Wed, Aug 19, 2009 at 8:56:15 AM | Interior Elevation linewieghts
cholden
cholden Avatar
I went into VG and removed all overrides. The walls and ceilings went back to their original set line weight (2 for cut ceiling and 4 for cut walls). The cabinets remained the same. I used override on the casework and selected the thickest lineweight available. They changed to the thicker lineweight. I tried to override using the thinnest lineweight - they did not change. It seems like it's trying to make my 1 lineweight my 4 lineweight only for certain elements. The linework tool changes it to a thinner lineweight so that made me think it wasn't a lineweight settings issue. It's like the families are confused. I tried transferring project standards from a project not experiencing these issues and this also did nothing. I deleted my local and resaved a new one. I'm sure it's a project setting as you said, but I can't seem to find which setting.
Wed, Aug 19, 2009 at 1:57:24 PM | Interior Elevation linewieghts
cholden
cholden Avatar
Has anyone else experienced this?
Wed, Aug 19, 2009 at 2:02:43 PM | Interior Elevation linewieghts
cholden
cholden Avatar
Ok - found it. Someone switched the silhouette line weight setting under advanced model graphics to wide lines. I just switched it back to none and reapplied my template and it worked!
Interior Elevation Tags
Mon, Jul 21, 2025 at 11:28:06 AM
Revit 2011 Multiple Interior Elevation References
Wed, Oct 26, 2011 at 9:01:48 AM
Interior Elevation not visible in drop down
Thu, Feb 6, 2014 at 9:19:32 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
CAD import disappears in interior elevation
Fri, Dec 6, 2019 at 12:40:46 PM
Page generation time: 0.4060
