Forums >> Revit Building >> Technical Support >> composite columns
Tue, Aug 18, 2009 at 1:59:20 PM | composite columns
osanchez76
has anyone run across a composite column?.. i am looking for a steel wide flange embedded in concrete rectangular column.
will i have to simply put in two columns on top of one another?
Thanks.
Mon, Aug 31, 2009 at 10:17:41 AM | composite columns
apanico
Osanchez76,
 How did you handle this - I have the same question.
Edited on: Mon, Aug 31, 2009 at 10:18:19 AM
composite panel walls
Fri, Feb 25, 2011 at 1:32:37 PM
composite column
Mon, Oct 16, 2006 at 1:53:30 AM
Making a Composite Mechanical Roof plan
Mon, Sep 27, 2010 at 4:33:50 PM
Composite facade cladding (FRP FACADE FOR RAK GATEWAY)
Fri, Feb 14, 2014 at 7:47:52 AM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Page generation time: 0.5257
