8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Making in place walls look like walls in plan
20 Posts No Rating |
I have an 18" wall that has different type of punched openings in it, slanted, circular etc.
Not hard to achieve w/ edit profile. But in plan this thing is just like a blob. How can I show it like it would be built, i.e. two separate mtl stud walls and closed off where openings occur?
The easy thing is too draw them as detail lines, but...
Is there away to convert in place walls to walls of a certain type?
Any help?
Thanks.
See attached pic.. it is wall on left.
is your wall made of 2 stud layers? it looks like one material...
edit the wall family to be what you are going to build like, 2 stud layers + your finish layers (if you have them) and it should look like you want when you cut...
Ok Thanks,
and then how will I get it to close the section where I edited the profile?
do you mean like this?
Revit 2013 making walls by faces and some walls are very strange... please help! |
Wed, Jun 19, 2013 at 7:05:58 AM
My walls do not appear in an underlay on my roof plan. |
Fri, May 29, 2009 at 7:27:34 AM
Walls in Framing Plan |
Fri, Dec 21, 2012 at 1:08:42 PM
Walls do not show up in plan view |
Tue, Mar 10, 2009 at 1:49:55 PM
Placing Electrical on Walls of different levels that are in same view |
Thu, Mar 5, 2015 at 9:41:25 AM
