Forums >> Revit Building >> Technical Support >> beam finishes
Sun, Aug 16, 2009 at 9:09:46 AM | beam finishes
wbenatti
hi, I have an isolate concrete beam in a midlle of a room and I want this beam with a 25 mm finish material in every beam side , how can I get this?? I´ve tried to enclose the beam with a wall (25mm large in all faces) changing the height of wall base level. Please, that's the best way to make this? Thanks.
Mon, Aug 17, 2009 at 7:08:41 AM | beam finishes
I'm sorry but this question is not clear.  Are you adding something like fire proofing?
Fri, Sep 14, 2012 at 11:47:49 AM | beam finishes
raniere
if u are not using revit str later, just create a wall family made of concrete.. simple as that
Fri, Sep 14, 2012 at 1:28:10 PM | beam finishes
wbenatti
Thanks Raniere.
Wed, Sep 19, 2012 at 3:11:30 PM | beam finishes
raniere
even, if you are going to use material schedules later, you will notice revit has a lot of miscalculations in what regards to joining structural beams into walls.... for instance just work as i said.. for columns and beams just create concrete walls (for beams inside walls use a sectional (stacked) wall.. kind of workful but precise if u gonna schedule..
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
floor finishes
Thu, Jul 1, 2010 at 7:19:37 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
Page generation time: 0.0885
