Forums >> Revit Structure >> Technical Support >> Solid cutout from walls
Sun, Aug 16, 2009 at 6:36:45 AM | Solid cutout from walls
SteveB
3.5 Stars: 5 Votes
is there a way to make some sort of void form that forms a cutout of a wall (other than wall->edit profile)?  somehow attach a void form to a wall?
Sun, Aug 16, 2009 at 7:03:15 AM | Solid cutout from walls
4 Stars: 205 Votes
Did you try to create the "Void" in a family like "Generic Model Wall Based" or "Generic Model Face Based", for example???
You could explain better what really do you need/want...
Sun, Aug 16, 2009 at 8:15:22 AM | Solid cutout from walls
SteveB
3.5 Stars: 5 Votes
that would work.  I was trying to create a recess in a wall, not going all the way through.
Sun, Aug 16, 2009 at 8:47:10 AM | Solid cutout from walls
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
No problem, you can still do what Ty said. Just constrain the void to a certain distance from the wall face so it doesn't go all the way through. 1"...2" 3" etc.
Or even better, you could have a dimension / length parameter for 'recess depth' to control the depth.
frosted glass with image cutout
Fri, Sep 23, 2016 at 4:51:32 AM
Changing Text Box Cutout
Thu, Feb 14, 2013 at 11:06:48 AM
cutout in a concret wall
Tue, Jan 29, 2008 at 11:21:10 AM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Render: Avoiding a hollow element when using "Cutout"
Tue, Jun 9, 2015 at 2:00:10 PM
Page generation time: 0.8877
