Forums >> Revit Building >> Technical Support >> Walls, Windows Furniture ect missing on level2 plan
Sat, Aug 15, 2009 at 12:56:31 AM | Walls, Windows Furniture ect missing on level2 plan
EssG
Hi,
Anyone know whats happening here. This was a project created in Rev2008 and updated to 2009. All the plan views are there but level 2 nothing but overhead lines, plan regions, stair annotations & gridlines  showing. All walls, window doors and furniture is gone. I have checked the light bulb and they are not hidden in view nor temp under the sunglasses. Tried all detail  levels, checked the cut plane & visibility/graphic overrides but all the items missing is checked.
Plan views for level1 & 3 is good
Have no idea where else to look, so any help will be greatly appreciated.
Thanks
Ess
Sat, Aug 15, 2009 at 2:18:59 AM | Walls, Windows Furniture ect missing on level2 plan
EssG
plan views
Sat, Aug 15, 2009 at 8:55:02 AM | Walls, Windows Furniture ect missing on level2 plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Maybe try deleting the plan view and then recreate it?
Maybe do a 'savesas' first so you don't make matters worse.
Sat, Aug 15, 2009 at 9:02:42 PM | Walls, Windows Furniture ect missing on level2 plan
EssG
Thanks for that Daryl..it workes but means I have to re-tidy the plan view (hiding all I need to hide) and I loose  my kitchen Callouts that were created from the old level 2 plan.
Any other way to do it so I dont loose that work?
Thanks again for the help
Sat, Aug 15, 2009 at 11:03:35 PM | Walls, Windows Furniture ect missing on level2 plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
So now compare the view properties, view range, (plan regions) and visibility graphics between the new view and the old view and try to determine the cause of the problem. Then go back and manually adjust the original view.
Or maybe just use the 'create template from current view' from the new view and then 'apply new template to current view' to the older view? Basically clone all the view settings on the new view (that is working correctly) and apply it to the old view. So you can retain all your callouts etc.
Sun, Aug 16, 2009 at 5:42:55 AM | Walls, Windows Furniture ect missing on level2 plan
EssG
Thanks..All the setting were exactly the same, so NO idea why its doing it. Had to  clone things over.
Anyone can have any idea why it did this and what one can do to prevent it happening again?
Thanks
Demolished walls overlap furniture in plan.
Mon, Nov 26, 2012 at 1:08:02 PM
Color fill in area plan convering walls, furniture etc.
Mon, Feb 26, 2007 at 9:16:40 PM
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
Showing windows on the floor plan
Sat, Feb 28, 2009 at 7:07:23 AM
Furniture Visibility
Mon, May 21, 2012 at 11:33:48 AM
Page generation time: 0.7368
