Forums >> Revit Building >> Tips & Tricks >> Interactive Web-Based Model Viewing
Thu, Aug 13, 2009 at 4:19:39 PM | Interactive Web-Based Model Viewing
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
You can use the Autodesk Seek Viewer plug-in as a viewer that is even lighter and easier to use than Design Review to view your Revit models (DWF versions) on the web:
1.) Once you have your Revit model published to a 3D DWF, go to the Autodesk Seek website and select a family to view 3D in the Autodesk Seek Viewer
2.) If you haven't been to the Autodesk Seek website before, download and install the plug-in - save the plug-in, you'll want it later.
3.) Once installed and viewing the family, right-click and select copy the source code to a blank notepad document.
4.) Sift through the code (theres not a whole lot to it) and replace the source location of the Autodesk Seek family with the location of your DWF. There are additional parameters for background color and gradience, intital camera view parameters such as pitch, roll, elevation and zoom factor you can play with.
5.) Save the file with the .html file extension
6.) Open the .html file in Internet Explorer and Voila! You now can view your Revit model in a simple, lightweight, easy to use viewer on the web with all the same amenities (render modes, interactive splicer, etc) as the Autodesk Seek website.
Anyone who has ever been to the Autodesk Seek website and installed the Autodesk Seek viewer plugin can view these right away; and what about the rest who have not? Well, you'll have to put a link on your website so they can install it on there machines; thats why I suggested to save the plug-in when downloading it from Autodesk.
This is great for large multi-unit development websites where you could have a site map of the development and link to an interactive 3D model of each unit. And it's simple enough that Joe-Shmo off the street can use it. A lot easier to use and less involved than Design Review.
Edited on: Thu, Aug 13, 2009 at 4:20:33 PM
cad.web.print
Thu, Feb 18, 2010 at 11:09:03 PM | Interactive Web-Based Model Viewing
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Here is a link to a live, working example. Smile
cad.web.print
Fri, Dec 6, 2013 at 5:35:52 AM | Interactive Web-Based Model Viewing
trufla
I'm stuck at the first step Sad i have installed the plugin, but then when i paste the code it says that there is no plugin available to display the content..
View not visible in interactive viewing pane?
Wed, Mar 14, 2007 at 11:09:33 AM
3D Transparent Viewing
Mon, Jun 9, 2008 at 5:45:00 PM
New Website - Web based viewer for Revit Model
Wed, May 25, 2016 at 1:07:45 AM
interactive virtual tour created from revit model - movie demo
Mon, Feb 8, 2010 at 4:28:43 PM
camera icon interactive
Thu, Sep 3, 2009 at 1:51:08 PM
Page generation time: 0.5946
