Forums >> Revit Building >> Technical Support >> import camera to revit
Thu, Aug 13, 2009 at 3:23:55 PM | import camera to revit
SWsam
Does anyone know if it is possible to import a camera view into Revit 2009?  Any kind of camera from any other program?
 Thanks,
SWsam
Thu, Aug 13, 2009 at 4:18:02 PM | import camera to revit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You can 'import' just about any image file into revit. If you can save the camera view to an image file you are in business. You may also want to look up 'decal' in REVIT for renderings that contain imported images.
Thu, Aug 13, 2009 at 5:04:00 PM | import camera to revit
SWsam
Sorry, I should be more clear.
I mean the actual camera.  Like when you export fbx and import it in Max you get the camera with it... But you can't import fbx into Revit, so a camera you set up in Max can't be transfered to Revit.
SWsam
Thu, Nov 26, 2015 at 12:50:46 PM | import camera to revit
lpnoble
This a good question, I render in Revit and want to camera match in Max or sketch-up. How do I get that camera into Revit?
Camera-Icon interactive placed with camera
Thu, Sep 3, 2009 at 10:57:30 AM
Can't create camera or walkthrough on first floor but can on others. Why?
Wed, Nov 19, 2014 at 10:32:39 AM
Camera Angle Matching
Mon, Oct 18, 2010 at 6:52:26 AM
Revit 9.1 walkthrough resets camera path and active camera
Thu, Jul 19, 2007 at 11:19:33 AM
Materials in a camera view
Mon, Mar 25, 2013 at 8:17:41 AM
Page generation time: 4.8980
