Forums >> Revit Building >> Technical Support >> Does Revit 2009/2010 work properly to on Windows 7
Wed, Aug 12, 2009 at 7:35:28 PM | Does Revit 2009/2010 work properly to on Windows 7
YouiGetWhatYouGive
I am having a major hinderence with vista, and I wonder if it followed threw to Windows 7. I need to see my components and vista wont let me. Will Windows 7?
Wed, Aug 12, 2009 at 8:44:52 PM | Does Revit 2009/2010 work properly to on Windows 7
msim007
I am running 2009 on a Windows 7 laptop and so far it is working well.
Windows 7 in noticeably snappier than Vista.. performance about on par with XP.
Wed, Aug 12, 2009 at 8:54:02 PM | Does Revit 2009/2010 work properly to on Windows 7
YouiGetWhatYouGive
Can you see your components as pictures. In the window before you open them?
Thu, Aug 13, 2009 at 5:12:19 AM | Does Revit 2009/2010 work properly to on Windows 7
msim007
Yes they show up fine.  I have only just finished setting all my software up and have hardly used it but so far it seems very good.  I will be using it a bit over the next couple of days so I'll post again with any further observations.
Had a slight problem with the bluetooth drivers (I use a bluetooth mouse...) but that has been sorted.
It runs 3d studio nicely as well.  I hated Vista but so far windows 7 seems like a winner.
My laptop is a Vaio and I had removed vista business and installed XP but the sony xp driver package just didn't perform.
As a comparison vista used 1G of ram just sitting there - Windows 7 uses .947 while running Revit (admittedly with only a small model but still a vast improvement)
Fri, Nov 20, 2009 at 5:44:22 PM | Does Revit 2009/2010 work properly to on Windows 7
pepsiqueen
pepsiqueen Avatar
I am looking to change over from XP to windows 7. have you found any software issue with Revit? The post is a few months old.
I'd rather be riding at whistler. or highland. thats good too.
Sat, Nov 21, 2009 at 6:15:03 AM | Does Revit 2009/2010 work properly to on Windows 7
4 Stars: 205 Votes
Check this: http://bimboom.blogspot.com/2009/11/autodesk-windows-7-officially-supported.html?utm_source=feedburner&utm_medium=email&utm_campaign=Feed%3A+Revit3dcomJoinTheRevitlution+%28Revit3D.com+Join+the+Revitlution+*%29
Edited on: Tue, Jun 1, 2010 at 3:30:53 AM
Thu, Dec 17, 2009 at 6:39:23 PM | Does Revit 2009/2010 work properly to on Windows 7
pepsiqueen
pepsiqueen Avatar
As it turns out, revit 2010 does not function on a 64 bit windows 7 machine. something to do with the compatibility of the 2008 version of C++ that revit utilizes. Our IT guy is working on it, but i just thought i would share. In the time between bluescreens however, I found that the quicks renders are amazingly fast and nice.
Mon, May 31, 2010 at 11:31:20 PM | Does Revit 2009/2010 work properly to on Windows 7
EssG
msim007...is your Revit 2009 the 32 or 64 bit version....I'm looking to getting a new laptop with Win7 and have 2009 Arc 32bit , so knowing it works fine will be a great help
Cheers
EssG
Tue, Jun 1, 2010 at 3:15:14 AM | Does Revit 2009/2010 work properly to on Windows 7
msim007
I have run revit 2009 & 2010 on windows 7 32 bit with no problems and have run 64bit on vista.
The only problems I have had are with 2010's lame ribbon interface.
Windows 7 32 bit is certainly much nicer than vista but personally I prefer XP64 for performance.
Hoppe that is helpful
Tue, Jun 1, 2010 at 3:43:44 AM | Does Revit 2009/2010 work properly to on Windows 7
EssG
Thanks for your reply msim007 ...The lap top comes loaded with Win7 64 bit only so I'm not sure how that will be with Revit 2009 32 bit.
Wed, Jun 2, 2010 at 5:26:05 AM | Does Revit 2009/2010 work properly to on Windows 7
#11
msim007
It should run fine - However if you are using a legit copy you should be able to switch to 64 bit for no extra cost...
I just rang my vendor and asked for a 64 bit version.
Wed, Jun 2, 2010 at 4:52:09 PM | Does Revit 2009/2010 work properly to on Windows 7
#12
EssG
Thanks for that info...thought it was only subscribers..will contact them if I run into problems
Cheers
Thu, Jun 3, 2010 at 4:25:04 AM | Does Revit 2009/2010 work properly to on Windows 7
#13
msim007
Actually you should be able to download the 64 bit version from the website come to think of it...
Good luck
Opening a 2010 file in 2009
Thu, Jul 16, 2009 at 8:51:56 AM
Revit 2009 and Windows 7
Fri, May 14, 2010 at 7:56:23 AM
Massing differences Revit 2009 and 2010
Sun, Apr 26, 2009 at 10:03:39 PM
Revit 2010 and Revit 2009 families error
Mon, Sep 21, 2009 at 1:35:48 PM
Does Revit 2010 work on Windows 10?
Fri, Jan 22, 2016 at 10:45:07 AM
Page generation time: 1.6967
