Forums >> Revit Building >> Technical Support >> display order
Mon, Aug 8, 2005 at 1:21:23 PM | display order
dRad
Is there an equivelent display order command that can be used to organize elements in Revit? Specifically, in creating a titleblock I am having issues with filled regions overlapping linked images and covering them from view. The intention is to maintain the filled region in the background but it keeps appearing in the forground, covering the image. Is there a fix for this problem?
Wed, Aug 10, 2005 at 1:24:03 AM | RE: display order
eldados
eldados Avatar
4.5 Stars: 8 Votes
click on the linked image/dwg and use the bring forward or send back tool
Thu, Aug 11, 2005 at 10:17:06 AM | RE:
dRad
Where are these commands located? under a pull down menu? I cant seem to find them...
Thu, Aug 11, 2005 at 10:23:24 PM | RE: display order
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately images don't have the same capabilities as the filled regions. Images cannot be brought forward and back as per filled regions and there is no way to send a filled region behind an image in a titleblock. Also families don't have the ability to send front/back at all. One for the wishlist...
Tue, Mar 27, 2007 at 11:48:55 AM | display order
Vale
I have a demo-wall that is covering a new cabinet. I have try to move the cut plane but then other objects do not show as I want. Is there any way to move the demo wall to back and have the cabinet to shows properly?
Thanks a lot,
Display order
Tue, Jul 9, 2013 at 9:35:53 AM
Filled Region display order
Tue, Jan 26, 2010 at 12:29:57 PM
New to Revit. Need help with display order
Thu, Jul 1, 2010 at 5:29:27 AM
display order command and reset visibility graphic setting
Tue, Jul 31, 2007 at 2:51:00 PM
Plot Order
Tue, Jan 3, 2012 at 9:40:18 AM
Page generation time: 0.3693
