Forums >> Revit Building >> Technical Support >> Muntin Thickness
Wed, Aug 12, 2009 at 2:27:16 PM | Muntin Thickness
LKilgore
How do you make a muntin thickness in a curtain wall thicker? I also need to set the height to a specific hgt. What I am doing is making a generic window representation for a design model. I am just trying to get it to look similar.
I am using Revit 2010 MEP
In the rendering photo I am using one curtain wall to make the full hgt of this window. I want to make the 2 main muntins thicker to represent the "separations" that are larger
LKilgore
Revit 2010/ ArchiCAD12.us/ Constructor 2008
2.5 GHz Intel Core Duo MacBook Pro 15.4"
GeForce 8600M GT 512MB
Wed, Aug 12, 2009 at 2:28:48 PM | Muntin Thickness
LKilgore
This smaller window in the render picture has not been stretched to the full 2 story hgt yet. May be a little misleading of what I am trying to do by showing it as is now.
LKilgore
Wed, Aug 12, 2009 at 3:01:27 PM | Muntin Thickness
Just use a different mullion....make a new type with the profile and dimensions you want.
Wed, Aug 12, 2009 at 3:13:33 PM | Muntin Thickness
LKilgore
Thanks, it was right in front of my face. I was changing the thickness horizontal instead of vertical. D'oh
LKilgore
muntin parameters for variable windows
Wed, Dec 13, 2006 at 4:10:57 PM
Muntin parametric array for a window
Thu, Mar 22, 2012 at 10:55:28 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:44 AM
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Page generation time: 2.2243
