17 Users Online (15 Members):
Forums >> Revit Structure >> Technical Support >> Reinforcing Tags
Good morning all, I am wondering, if many of you are having the same problems with Reinforcing Tags as I am. For us it is an office standard to show on plan bottom bars as dashed and top bars as solid. Also The hook orientation is important, yet revit only shows it one way and does not allow for it to be flipped. I am wondering if any of you have had to deal with this and if so, how did you deal with it. Any help would be greatly appreciated.
Welcome to the REvitlution!!! |
10 Posts No Rating |
For plan view I edited the family for area reinforcement symbol and made 2 differet types one for top reinforcement where I changed the linetype for the reinforcement to hidden and other for bottom reinforcement
3 Posts No Rating |
@Hakon could you please share that familes showing hidden line bars ..........i changed object style in reinforcement symbol family but it didnt work. Thanks
Hakon has not been here since 2010 so I don't believe you will get a response from him/her.
3 Posts No Rating |
Thnx Hub
2 Posts No Rating |
Not to hijack this topic but since we're talking about Reinforcement Tags, is there a way (in Revit 2014) to use a Multi-Rebar Tag as a normal Tag and not with the Dimension object attached? I looked at how the Multi-Rebar Tag is configured in Revit but it doesn't seem to be applicable to a regular Tag. Thanks in advance.
visibility of reinforcing from linked structural model in architectural sections |
Thu, May 29, 2008 at 3:44:37 PM
REINFORCING MOVES MODEL |
Thu, Oct 6, 2005 at 3:36:36 PM
Test Labels with psuedo dimension lines |
Tue, Sep 20, 2005 at 9:45:16 PM
Wall with multiple different tags |
Tue, Jun 30, 2015 at 7:14:44 AM
2D Reinforcing Family - not recognizing View Scale |
Tue, Jan 2, 2018 at 2:16:32 PM
