Forums >> Revit Building >> Technical Support >> Uncompress Walkthrough Codec Problem
Wed, Aug 12, 2009 at 9:07:50 AM | Uncompress Walkthrough Codec Problem
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Hello.... I just finished the 1650 frames rendered walkthru and i can't open it.... it's giving me a codec problem using WMP. it's an AVI format. I didn't compress it. I simply used "uncompress" now i can't play it.... it's a big file - 3.6 gb. need your help please so i can play it. Thanks!!!!
 "If you tell the truth, you don't have to remember anything"
Thu, Aug 13, 2009 at 11:45:50 AM | Uncompress Walkthrough Codec Problem
BDerrick
3.5 Stars: 3 Votes
wow, even if you could open it I doubt it would be a smooth animation.  The file is just way to big.  I always use these settings: 30fps, Dimensions at about 640x480, Cinepak Codec, key frame every 15 frames.  I'm not sure about the codec problem though.  Good luck
2011 Revit Architecture Export Walkthrough CODEC
Tue, May 18, 2010 at 9:43:10 AM
Walkthrough problems in Revit 2012 Win 7 64 bit
Thu, Sep 29, 2011 at 6:07:53 PM
Walkthrough playback error
Tue, Feb 24, 2009 at 6:38:10 AM
HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009
Sun, Apr 26, 2009 at 8:38:34 PM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
Page generation time: 0.7974
