Forums >> Revit Building >> Technical Support >> Problem with revit file
Mon, Aug 8, 2005 at 3:09:20 AM | Problem with revit file
alangero
Can anybody help I have been given a project file to do some further work on (helping a friend out), but when I am trying to create mullions on curtain walls there are none available. When I create a new project the mullions work fine. What is going on?
Mon, Aug 8, 2005 at 6:42:40 AM | RE: Problem with revit file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
They have been purged out of the project... You'll need to locate them in the project browser, right click and create new types...
Mon, Aug 8, 2005 at 12:41:21 PM | RE: Problem with revit file
alangero
Tried creating a new mullion, but it won't let me adjust the properties or import another. tried creating other things like Gutter's etc, no problem. there are about 4 types of Mullions and they have no values added to them.
Mon, Aug 8, 2005 at 4:29:46 PM | RE: Problem with revit file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Open a fresh project and use transfer project standards on the mullions to get new types across...
Tue, Aug 9, 2005 at 2:09:03 AM | RE: Problem with revit file
alangero
Good advice. But it changed everything but the mullions. I go from one project to the next and the mullions are ok in the new project but are still currupt in the one I tried to transfer to. Thanks.
Tue, Aug 9, 2005 at 3:03:39 AM | RE: Problem with revit file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Last option... draw a curtain wall and apply the mullions that you want to use to it in a fresh project. Then copy and paste it into the other project. If this doesn't bring them across you file is very ill and requires sending to support.
Thu, Aug 11, 2005 at 11:53:35 PM | RE: Problem with revit file
alangero
Thank's very much for the advice. I could not do any of these things successfully so I started again. Now all is fine. Thanks
Central File Problem and importing problem
Thu, Jun 25, 2009 at 1:40:11 PM
Problem in dwg file import Revit then export gbXML file
Sat, Sep 1, 2012 at 8:57:09 PM
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
Export to dwg problem - I want it all in 1 file :) - please heeeelp
Wed, Jan 23, 2008 at 4:36:53 AM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Page generation time: 2.1797
