Forums >> Revit Building >> Technical Support >> Copy Material Styles from one Revit model to another
Tue, Aug 11, 2009 at 12:05:04 PM | Copy Material Styles from one Revit model to another
jatownsend
We have a project that has 4 different buildings that are in 4 separate models, which are then placed on a master file.  Each model has slightly different material styles as individuals customize their drawings.  Is there a way to export tha material styles for all materials and import them into all drawings so they are uniform?
Tue, Aug 11, 2009 at 12:42:31 PM | Copy Material Styles from one Revit model to another
Do you want them all the same?  If so, then they all must be named the same and you can use transfer project standards.  If you want them to be according to their individual proects, their names need to be unique.
Fri, Aug 14, 2009 at 10:12:52 AM | Copy Material Styles from one Revit model to another
jatownsend
Thanks.  That is what we were looking for.
Line Styles
Thu, Oct 4, 2007 at 3:38:55 PM
Change Default Family Category Model Object Styles
Thu, Jun 18, 2009 at 4:23:45 PM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Copy model?
Fri, Nov 24, 2006 at 6:35:27 AM
Page generation time: 2.2409
