22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> Unintended Consequence
4 Posts No Rating |
I started making a window family on my own starting with a toilet-high type and how it appears when inserted is weird than what I expect. I guess it's because of the clipping or view range. I tried raising up the clipping level and there was a slight improvement viz. - the cutting edges of the wall opening appeared but that's just about it, before it looked like a vessel floating on a canal. But still. the window remains a rectangular floating object above the cut portion of the wall. It definitely represents the uncut header of the window frame. There's not much I can think of to show that the cutting should be on the frames and the glass.
8 Posts No Rating |
Try setting the visibility of the header so that it doesn't show in plan views.
considering that adjusting the view range helped, you might try a plan region with different view range settings.
Title View - Unintended Text Wrapping |
Tue, May 12, 2020 at 9:48:59 AM
NEW Gyp on EXISTING Stud wall |
Mon, Mar 5, 2007 at 8:59:01 AM
Dimension String |
Tue, Aug 29, 2006 at 5:55:23 PM
difference between two options of callout |
Thu, Mar 24, 2011 at 10:08:39 AM
Tag moves to another location after reload og family |
Wed, Jun 17, 2015 at 5:56:43 AM
