Forums >> Community >> The Studio >> Wall hosted family can't be hosted on curtain wall?!
Mon, Aug 10, 2009 at 4:59:27 PM | Wall hosted family can't be hosted on curtain wall?!
davedarch
Revit's use of curtain wall is very confusing. Sometime's it acts like a wall sometimes it doesn't. Anyway, I created a parametric sun shade using the wall hoted family template. Since I was trying to get the parameters right it took a long time. This sun shade is offset from a curtain wall. Now, when I load the family into my revit project, it won't host on my curtain wall. This is extremely frustrating. What can I do about this? I couldn't change the type to make it just generic. It seems I have to copy everything over to another family. How would I go about doing this efficiently? Would copying elements over still retain all of my parameters? Also, I tried following Mr. Spot's tutorial on this and my louvre/fin angle parameter seems to be broken. I'll attach my file, any help would be great!
Thanks!
-Dave
Mon, Aug 10, 2009 at 5:13:02 PM | Wall hosted family can't be hosted on curtain wall?!
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
If you are in a rush to do this... you can "cheat" it. Just create a generic wall - just enough so you can use it to host your created sun shade family, if needed... change your generic wall material to glass-transparent to match your curtain wall panel. It's a lazy way to do it but i think it would work.
 "If you tell the truth, you don't have to remember anything"
Tue, Aug 11, 2009 at 6:34:38 AM | Wall hosted family can't be hosted on curtain wall?!
This is one of those..."I would have done this differently".  We have found that unless you need to cut the host, don't use wall/floor/ceiling/roof based families.  Instead use a face based.
Too late for you now.  Is there wall above or below your element?  If so, then can that host your entity and just move its vertical location.  You can use tricks like this if the host is still somehow in view.
Thu, Oct 21, 2010 at 3:16:28 PM | Wall hosted family can't be hosted on curtain wall?!
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I ran into this same issue. I am using a "curtain wall" for a toilet partition (I know there are other way...just testing to see if it would work) and I need to attach a piece of equipment to the partition wall. I know about wall hosted and face based families, but the face based family is weird to work with in relation to vertically place families. Is there a way to change the "reference" host face to a vertical one so I can model LIKE a wall hosted family?
Thu, Oct 21, 2010 at 3:32:43 PM | WWHub
TKennedy
4 Stars: 8 Votes
Quoting WWHub from 2009-08-11 06:34:38
You should still be able to cut the host with face based families. I'm fairly certain that I've done it.
Thu, Oct 21, 2010 at 3:35:26 PM | Wall hosted family can't be hosted on curtain wall?!
James,
I don't have any problems using face based on vertical or even upside down.  Just build it on the template knowing that what is plan is the face of whatever.
Now to place these face based objects... do it from a 3d view is easiest.
Thu, Oct 21, 2010 at 4:05:04 PM | Wall hosted family can't be hosted on curtain wall?!
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I hear what you are saying and I can also work with face-based families, but I am having to train others to create families and I am running into difficulty because I have to make sure they know the same thing.
By the way, how to you handle the Visibility setting and symbolic lines for face based families. It seem a little weird to have to turn the visibility off for "Front/Back" when you need a "Plan view" symbolic.
Fri, Oct 22, 2010 at 7:13:04 AM | Wall hosted family can't be hosted on curtain wall?!
For visibility, you just have to "translate" your references.   Plan really is "front" for wall hosted elements.  So symbollic lines placed in the plan will be in the plane the item is hostd on - so if walls - if placed in plan view of the family, they will be seen in model elevation.
For anyone that hand drafted this thought process has never been an issue.
Wall hosted or Surface hosted
Mon, Sep 26, 2016 at 3:40:49 PM
Wall hosted Families
Wed, Feb 11, 2009 at 7:29:20 AM
Wall hosted family appears in schedule, but not in a room
Sat, Nov 19, 2011 at 12:58:14 PM
Wall hosted familes cutting through 2 types of walls
Thu, Oct 27, 2011 at 10:42:15 AM
Coverting wall hosted to face hosted familys
Wed, Jun 23, 2010 at 6:11:07 PM
Page generation time: 3.9947
