17 Users Online (15 Members):
Forums >> Revit Structure >> Technical Support >> View a select floor in 3D
23 Posts No Rating |
I am new to Revit and I cannot figure out on my 5 story building how I can look at each floor individually in 3D. I have the mastering revit 2009 but I cannot figure out how to see each floor in 3D separate.
LKilgore Revit 2010/ ArchiCAD12.us/ Constructor 2008 2.5 GHz Intel Core Duo MacBook Pro 15.4" GeForce 8600M GT 512MB |
check out the setion box. that would be one method hth
Thanks that worked. Kind of a weird way about going to get that view.
7 Posts No Rating |
Open up a 3D view. In view properties, under the extents parameter, check section box, A section box will appear in 3D view. Click box and click the arrow on top or side of box and drag until desired floor is visible. In project browser, rename 3D view to Floor Level. Duplicate new view and rename it to the next floor level. Adjust section box to the new floor and so on.
Unable to select ductword! (on 1st floor only) |
Fri, Oct 15, 2010 at 5:15:41 PM
Floor Drains Will Not Select |
Sat, Feb 26, 2011 at 10:13:55 AM
Find objects in views using "Select All Instances in View" |
Tue, Sep 3, 2024 at 5:10:21 AM
Select all instances by view |
Mon, Apr 26, 2010 at 7:11:08 PM
Seriously Frustrated!!! |
Tue, Aug 18, 2009 at 12:43:37 PM
