Forums >> General Discussion >> Revit ROI >> Revit 2009/2010 Autostart shortcuts (Revit Ribbon)
Sun, Aug 9, 2009 at 7:34:14 AM | Revit 2009/2010 Autostart shortcuts (Revit Ribbon)
4 Stars: 205 Votes
Take a look at this: http://bimboom.blogspot.com/2009/08/gift-for-you-wrapped-in-nice-ribbon.html
Edited on: Sun, Aug 9, 2009 at 7:34:37 AM
Sun, Aug 9, 2009 at 10:44:45 AM | Revit 2009/2010 Autostart shortcuts (Revit Ribbon)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thanks. Yes, if you actucally despise the new ribbon that much you can revert back to the old interface.
It's a toss-up that's for sure. Apparently when you switch the .ini files and switch back to the classic interface you do loose some functionality. I'm going to trudge along with the ribbon. (to trudge: a slow, laborious weary walk)
Sun, Aug 9, 2009 at 12:21:31 PM | Revit 2009/2010 Autostart shortcuts (Revit Ribbon)
coreed
coreed Avatar
4 Stars: 16 Votes
unless Autodesk brings back as the default option, i'll trudge along with the ribbon also.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Ribbon for Revit
Sat, Aug 29, 2009 at 2:09:53 AM
File locations in Revit 2009
Thu, May 29, 2008 at 6:02:29 PM
Massing differences Revit 2009 and 2010
Sun, Apr 26, 2009 at 10:03:39 PM
When selecting an object the element ribbon panel is not visible in Revit 2010
Fri, Aug 28, 2009 at 11:10:02 PM
Opening a 2010 file in 2009
Thu, Jul 16, 2009 at 8:51:56 AM
Page generation time: 2.4925
