20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> 8"cmu wall and 6" cmu wall
1 Posts No Rating |
does any one know how to create a cmu wall that is 8' tall, and then for 3 courses it turns into a 6" block?
check out stacked walls. hth
Yes seems like a natural 'stacked wall' scenerio. The default revit project template file contains a stacked wall type. All you need to so is duplicate that stacked wall, rename it and then change the nested wall types and heights as per your conditions. Stacked walls do loose some functionality but worth a try.
CMU wall reinforcement and detailing |
Mon, Nov 22, 2010 at 1:32:03 PM
CMU + brick wall- brick is NOT bearing |
Tue, Dec 22, 2009 at 3:16:30 PM
CMU HATCH - ALTERNATING 8" AND 4" BLOCK |
Wed, Sep 23, 2009 at 4:03:33 PM
How to add stucco to face of cmu wall |
Sat, Oct 23, 2010 at 2:59:05 PM
Wall Footings |
Tue, Dec 15, 2009 at 2:16:22 PM
