Forums >> Revit Building >> Technical Support >> Help me With Curves in Revit 2009
Fri, Aug 7, 2009 at 8:12:46 PM | Help me With Curves in Revit 2009
dpbittiker
I am having trouble modelling this shape parametically can anyone help me?  Thanks.
Fri, Aug 7, 2009 at 8:56:19 PM | Help me With Curves in Revit 2009
lunchtrayrider
3.5 Stars: 7 Votes
use an extrusion that has a different top and bottom. does that help?  check help, let me know if you need more info
I like scooters. and motorcycles.
Sat, Aug 8, 2009 at 5:29:07 AM | Help me With Curves in Revit 2009
4 Stars: 205 Votes
Use the Solid Blend.
Mon, Aug 10, 2009 at 2:34:01 PM | Help me With Curves in Revit 2009
dpbittiker
Thanks
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:44 PM
blending curves
Mon, Oct 13, 2008 at 12:22:38 PM
Revit 2018.2 Print to PDF Turning Curves into Polygons
Tue, Apr 17, 2018 at 12:30:39 AM
Multiple Curves and Angles with Sweep
Mon, Jun 24, 2013 at 1:34:46 PM
hip roofs with curves and different slopes each side
Fri, Dec 2, 2011 at 3:47:17 AM
Page generation time: 3.5855
