Forums >> Revit Building >> Technical Support >> Attaching double Tees to a sloped floor
Fri, Aug 7, 2009 at 1:18:59 PM | Attaching double Tees to a sloped floor
rm100
Hi,
I am trying to attach or host precast double tees to a floor in a parking garage. The floor has multiple slopes. I can't use a ramp because the ramp does not allow me to modify elevations of different points on it unlike a floor. What is the easiest way to host these double Tees to the floor? I have many many double tees and it would be helpful if there is an easy way to do this. I use revit 2010.
Thank you for your help.
RM
Fri, Aug 7, 2009 at 2:30:36 PM | Attaching double Tees to a sloped floor
Could your double tee family be built as face based?
Thu, Aug 13, 2009 at 12:59:26 PM | Attaching double Tees to a sloped floor
jhayden
jhayden Avatar
I have the same question. I'm trying to get pre-cast double tee's to slope in multiple directions. Has any progress been made on this post? WWHub, could you expand on the face based family?
Thanks
Thu, Aug 13, 2009 at 1:23:44 PM | Attaching double Tees to a sloped floor
I don't know what you guys are using for your T family.  I did a parking garage a few years ogo...Revit 5.? ... and I built my T as non-hosted - Not Vertical.  I could then place it and slope it in two directions but you can't warp it.  Top is still on a plane.  Today I might try a work plane based and see if I can set that plane in the project and place my tees on it.
The best thing to do is try a simple form in a junk project and see what works.
Cutting Ends Down For Sloped Double Tees
Thu, Apr 28, 2016 at 2:49:26 AM
Can't find precast concrete wall tees in Revit Structure 2012
Thu, Mar 15, 2012 at 9:53:47 AM
Attaching chairs to an extruded floor?
Tue, Feb 23, 2010 at 6:03:05 PM
Double Sloped Steel Joist
Thu, Dec 23, 2010 at 8:35:13 AM
Double sloped hipped roof
Mon, Jun 27, 2011 at 2:18:55 AM
Page generation time: 2.4764
