Forums >> Revit Systems >> Tips & Tricks >> modifying fixed windows
Fri, Aug 7, 2009 at 9:40:02 AM | modifying fixed windows
vinnygolfer
4.5 Stars: 4 Votes
i need some help with modifying a fixed window. i need to take a standard rectangle window and strech one end of it up. i'm working with 2010.
the windows are going in a gable end, and the top of the windows need to match the roof line.
any help would be appriciated.
thank you
Fri, Aug 7, 2009 at 10:13:11 AM | modifying fixed windows
It might be easier to use a storefront window and sketch the profile.  You can change the muillions to match what you need - just a profile shape.
Fri, Aug 7, 2009 at 10:29:22 AM | modifying fixed windows
vinnygolfer
4.5 Stars: 4 Votes
thanks
Modifying Families
Tue, Mar 10, 2009 at 9:55:47 PM
13
windows dont cut hole in walls.
Wed, May 25, 2005 at 1:37:18 PM
EQ Dimensions and Fixed Distances
Wed, Nov 27, 2013 at 1:26:36 PM
3D GHOST WINDOWS
Wed, Feb 6, 2013 at 11:06:52 AM
Curve topped windows
Mon, Nov 8, 2004 at 10:51:01 PM
Page generation time: 0.8518
