10 Users Online (8 Members):
Forums >> Revit Structure >> Technical Support >> Linking
16 Posts No Rating |
So I have to draw a full working model of a prison and draw the pipe in 3d well i have revit structure and i have autocad mep which is 3d can i draw my structure in revit the draw my pipe in acad mep?
I think no one answered this because there are a lot of things you should try on your own. Come back when you have a question resulting from a problem you encounter.
Well you could be right except for the fact that I would waste alot of time in the process so if someone knew somthing about it I wouldnt have to waste any of that time if it didnt work.
What I am saying is to open a file in one program do a little test then open that same file in the other. You know what it is that you need to do, we don't. That's not much to have to do....
Linking models with multiple sites |
Wed, Dec 6, 2017 at 9:43:09 AM
DWG linking into revit |
Mon, Jun 9, 2014 at 7:11:38 AM
Linking Other Models |
Tue, Aug 31, 2010 at 1:35:54 PM
Linking Revit Files for Sheet Coordination |
Fri, Jul 10, 2009 at 11:09:09 AM
Linking large files |
Wed, Aug 31, 2005 at 2:32:01 PM
