Forums >> Revit Building >> Technical Support >> Importing .3ds objects into revit OR a WORKAROUND??
Fri, Aug 7, 2009 at 1:26:39 AM | Importing .3ds objects into revit OR a WORKAROUND??
bowdea01
Hi,
 We are desperately trying to find a method of importing .3ds objects into revit. I know that they can be convereted to .dwg and .dxf files then imported but this will not work for very complex objects as the file becomes excessively large and the computer just cannot handle it.
Has anyone got any methods that have worked, I even thought that maybe another products plugin might work like archvision (converting .3ds to rpc content then into revit.)
Would be a major help if something could be found, autodesk have really let themselves down in this area. The fbx file format they have is only ONE way and that is out of revit which really really sucks.
Fri, Aug 7, 2009 at 10:23:19 AM | Importing .3ds objects into revit OR a WORKAROUND??
erland73
erland73 Avatar
4.5 Stars: 85 Votes
One workaround I've found is to import those files in SketchUp so you can save them as .SKP or export them in .dwg format (available only with SU pro), and then you can import those files in Revit......
import revit model to 3ds 7
Tue, Jan 29, 2008 at 10:34:17 AM
3ds Max Design 2009??? importing from Revit 2009???
Thu, Feb 26, 2009 at 8:01:56 PM
Importing Cad Files
Tue, Mar 31, 2009 at 8:36:59 AM
problems inporting from revit 2010 to 3ds max 2010
Sun, Mar 13, 2011 at 6:17:59 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:53 AM
Page generation time: 1.9566
