Forums >> Revit Building >> Technical Support >> EXTRACTING COMPONENT FROM AN UN-EXPLODED FAMILY
Thu, Aug 6, 2009 at 6:08:43 PM | EXTRACTING COMPONENT FROM AN UN-EXPLODED FAMILY
annateo301
Hi guys,
I loaded a disabled toilet with baisin and handrail. they are all linked to each other.
The problem here is that I wanted to explode that family and only extract the handrail from the family. Is that possible to do in Revit? If yes, how?
Thu, Aug 6, 2009 at 8:57:02 PM | EXTRACTING COMPONENT FROM AN UN-EXPLODED FAMILY
TomDorner
4.5 Stars: 25 Votes
You've got two options:
1.  Open the family, erase what you don't want, purge the erased objects and do a file "save as" and save as new family.
or
2.  Open the family, then do a File>Save to Library>Save Family (2009) then select family to save out.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
HELP! importing 3D objects cant be exploded
Fri, Nov 10, 2006 at 10:48:19 AM
Imported family is exploded in project
Fri, Aug 12, 2011 at 7:31:02 AM
exploded views and sheet feature in revit family editor
Mon, Mar 24, 2014 at 10:55:30 AM
exploded axonometric?
Mon, Jun 5, 2006 at 7:59:53 AM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
Page generation time: 0.6669
