Forums >> Revit Building >> Technical Support >> Acad Import - Origin to Origin
Fri, Aug 5, 2005 at 7:24:23 AM | Acad Import - Origin to Origin
remashiach
I am trying to import an autocad drawing using origin to origin but it will only do "centre to centre" as the origin is too far away I think. Is there anyway I can make it do this? I am trying to do this in order to relocate my project according to an autocad drawing but it's not working.... please help!
Fri, Aug 5, 2005 at 11:38:37 PM | RE: Acad Import - Origin to Origin
eldados
eldados Avatar
4.5 Stars: 8 Votes
do you have anything drawn in the Revit file? if not, just bring your Acad origin to origin and move your levels and elevation you have on the drawings, if you already drawn in Revit, you might have to move everything... have you tried moving your Acad to 0,0? or specifying origin point in Revit? just thinking out loud...
Mon, Aug 8, 2005 at 5:16:29 AM | RE: Acad Import - Origin to Origin
remashiach
Thanks. Thing is - I want my revit drawing to be according to where the acad drawing is so I do not want to move the acad drawing to 0,0. I want it to stay where it is. : (
Mon, Aug 8, 2005 at 6:41:13 AM | RE: Acad Import - Origin to Origin
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
sounds like the ACAD origin is pretty arbitrary if its so far away from the actual drawing. Nonetheless, you could import your dwg centre to centre to begin with, then move it to the appropriate location origin wise using spot co-ordinates to match you acad location of a particular point...
Wed, Aug 1, 2007 at 5:57:25 PM | Acad Import - Origin to Origin
Anchovi
I know this is an old post, but we are having a similar problem with importing ACAD dwg files.
In ACAD the dwg files line up exactly over the top of each other. However, when imported into RS2008, regardless of with positioning option you select, the dwg files do not overlay exactly on each other.
Does anyone have a solution or an idea as to why this might be????
 Please help
Point Clouds Origin to Origin
Tue, Nov 8, 2011 at 11:23:30 AM
Origin to Origin
Tue, Jul 5, 2011 at 8:18:16 AM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Mis-aligned Origin to Origin in linked Revit Architect into Revit Structures
Fri, Nov 18, 2011 at 7:26:33 AM
how do i insert dwg survey data that is far from origin (0,0)????
Tue, Sep 13, 2011 at 12:19:33 PM
Page generation time: 0.5015
