14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> shell beams
70 Posts No Rating |
hi guys, does anyone know where can I get a shell beam family? another question: i have draw precast con beams on my project with start level offset and end level offset at 3375. The problem is how can i make them visible in my floor plans?
What is a shell beam? You will probably have to make it yourself.
shell beam is something look like this(attached file)
I'm assuming that this gets a slab cast over it, you could very easily make a family of this type of shape, use the beam family starter so that you will have most of the options
Erm.. That is another problem.. I don't know anything about family.. I don't know how to create it.. Could you please briefly teach me?
It seems you are new to Revit, so welcome. Be sure to take advantage of the tutorials and guides that we at Autodesk have made available to help you learn Revit. Their is a families guide at: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13080413&linkID=9243097 Check out the how to articles in the left side menu while you are out there. A lot of good stuff to help you out. Also check out the architectural resource center: http://resources.autodesk.com/Architecture/Revit_Architecture HTH
Edited on: Fri, Aug 7, 2009 at 10:19:47 AM
Tom www.reviteer.com http://twitter.com/Reviteer |
No Revit Shell |
Tue, Jul 12, 2005 at 5:45:55 PM
Remove Working Views from Revit Projects with Python Shell Script |
Mon, Mar 25, 2013 at 12:43:53 PM
Multiple Tenant Finishes - One Shell |
Fri, Oct 3, 2008 at 1:47:22 PM
How to Delete all Empty Tags with Revit Python Shell |
Mon, Mar 18, 2013 at 2:37:48 PM
Timber Shell Structure |
Fri, Nov 30, 2012 at 3:39:18 AM
