Forums >> Revit Systems >> Technical Support >> aligning sections
Thu, Aug 6, 2009 at 8:33:00 AM | aligning sections
koolair
4.5 Stars: 2 Votes
The section symbol in plan view should be align-able.  That is, I don't want to rotate it to be in line with an angled wall.  I just want to hit align just like I do with pipes and ducts.  Any idea how to make it happen?
I tried to edit the section family so that I could make the section line a model line or something I could grab while in the align command, but it doesn't give me the option to edit.
Thanks
Joe
Thu, Aug 6, 2009 at 8:46:51 AM | aligning sections
Place a couple of sections on a sheet... stay out in your view.... move your title and watch what happens.  Revit will give you alignment lines automatically.  Just don't zoom in - this is not AutoCAD.
Thu, Aug 6, 2009 at 9:48:36 AM | aligning sections
koolair
4.5 Stars: 2 Votes
Actually, I'm trying to align the section line (head, line, tail) in a plan view (inside the model). I think it's also called a section marker.
The section box on a sheet is ok...i can align that.
Thanks
Thu, Aug 6, 2009 at 10:03:01 AM | aligning sections
You can rotate the whole section cut... line head tail... just click on it and rotate.
To align with something - just move your rotation point to a line on that object and rotate to another point along the object's line.
Edited on: Thu, Aug 6, 2009 at 10:05:41 AM
Thu, Aug 6, 2009 at 12:54:03 PM | aligning sections
koolair
4.5 Stars: 2 Votes
Thanks
Thu, Aug 6, 2009 at 12:57:25 PM | aligning sections
koolair
4.5 Stars: 2 Votes
well I guess this should be on a wish list of some sort.  I know how to rotate the section marker.  That was a huge step in the right direction which I learned about several months ago.
It would be quicker if I could use the align tool to do the same thing.
Thanks anyway!
Problem aligning views on sheets
Tue, Aug 12, 2008 at 9:48:23 AM
Aligning Dependent View across Sheets
Wed, May 7, 2008 at 11:41:51 AM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 2:07:57 AM
Aligning Grout Lines in Render Materials
Fri, Dec 16, 2011 at 6:47:21 AM
Aligning Sheets (Titles, Viewports, ETC.) HELP!
Tue, Mar 11, 2008 at 1:25:09 AM
Page generation time: 1.1138
