26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Unable to load view title.
15 Posts No Rating |
Hi. I'm using Revit 2010. I'm trying to use a view title without a bubble. I've tried loading the other view title families provided in the standard library and also created my own view title family and loaded it into the project. However, when I try to change the type of viewport, it does not appear in the pull-down list, as if it's not loaded into the project. I don't think I am doing anything wrong. Has anyone else had this issue? Thanks, John-Paul
You're not doing anything wrong - you just need to go a bit further. Go into the element properties of the view. Under title you will see all the kinds that you have loaded. Select a new one.
Thanks Tim. Worked a treat, that was really bugging me. Cheers.
View Title Line Thickness |
Thu, Jan 24, 2008 at 1:42:39 PM
Add Parameter to Family Category - View Title |
Tue, Jan 17, 2012 at 2:28:48 PM
Project Address Parameters for Title Sheet |
Thu, Mar 23, 2006 at 5:01:01 PM
Moving View Title |
Sat, Mar 6, 2004 at 9:46:28 AM
Modify View Title |
Wed, Jun 11, 2014 at 7:37:29 AM
11
